Feature Configuration - Messages
If the feature exists to interface with an external system, you can use this page to define the mapping between error and warning codes in the external system and our system.
Open this page using > > and navigate to the Messages tab.
Description of Page
For each message that may be received from an external system, define the Feature Message Category and Feature Message Code to identify the message.
A corresponding message must be defined in the
system message tables. For each message identify the
Message Number. For each new message, the Message Category defaults to
90000 (because an implementation's messages should be added into this category or greater so as to avoid collisions during upgrades).
Parent topic
