Viewing Erasure Configuration
The Erasure Configuration
All-in-One portal provides the ability to view the maintenance objects that are marked as eligible for erasure and maintain their erasure configuration entries in a single place.
To view a list of the eligible MOs, open  >  >
Press the edit icon to open a window in which the configuration values for that row can be changed.
Refer to
The Approach to Implementing Object Erasure for an overview of object erasure configuration.
Parent topic
