Function - Main
Use this page to define basic information about a function. Open this page using  >  >
Description of Page
Enter a unique Function code and Description for the function.
Use the Long Description to describe, in detail, what the function does.
Define the Internal Service that the function invokes.
Only page services can be invoked.
The tree summarizes the following:
• The fields sent to the service. You can use the hyperlink to transfer to the Send Fields tab with the corresponding field displayed.
• The fields received from the service. You can use the hyperlink to transfer to the Receive Fields tab with the corresponding field displayed.
• Scripts that reference the function. You can use the hyperlink to transfer to the script page.
Parent topic
