Designing Validation Algorithms
When designing your report definition, determine if cross validation should occur for your collection of parameters. In the Tax Payables Analysis report, there are two date parameters. Each date parameter uses the characteristic type validation algorithm to ensure that a valid date is entered. However, perhaps additional validation is needed to ensure that the start date is prior to the end date. To do this, a validation algorithm must be designed and defined on the report definition.
The system provides a sample algorithm RPTV-DT that validates that two separate date parameters do not overlap. This algorithm should be used by the Tax Payables Analysis report.
If you identify additional validation algorithm, create a new
algorithm type. Create an
algorithm for that algorithm type with the appropriate parameter values. Plug in the new validation algorithm to the appropriate report definition.
Parent topic
