Migration Data Set Export
To migrate data from one region to another, define a Migration Data Set Export. This establishes the export file name and identifies the migration request.
To view an existing migration data set export, navigate using > > . Use the query criteria to locate the desired data set.
Note that you can also initiate the creation of an export data set from the
Migration Request portal using the
Export button.
The export requires the name of an existing Migration Request.
Enter a unique
File Name for the export. Do not use spaces in the name, and do not enter the file extension or a path. The output location and file extension of the intended export file, which should appear in the
Export Directory and
File Suffix labels, are defined as described in the topic
Migration Assistant Configuration.
Enter an Export Description to provide information about the purpose of the export. Note that this field is not language enabled.
The Source Environment Reference is for information purposes. It should be populated with text that provides a meaningful description of the source environment. The default value is the URL of the source environment.
The
Migration File Version is only relevant if you are planning to import the file in a target environment that uses an older migration
file format version. Indicate the lower file format version that you wish the export to use.
Parent topic
