Configuring the Enterprise Geodatabase
Ignore this step if the Enterprise Geodatabase is already set up and the connection is established from ArcGIS Desktop.
To set up Enterprise Geodatabase, refer to ESRI ArcGIS instructions.
Select the database accordingly. Establish a connection to the geodatabase from ArcGIS Desktop and enable the data accessible from ArcGIS Server.
Refer to ESRI ArcGIS for more information.
Parent topic
