Creating Application Links in External Applications
When integrating Oracle Utilities applications with other external applications, you can create links from external applications to specific portals and pages within the Oracle Utilities applications (also known as "deep linking"). These links typically leverage Business Process Assistant (BPA) scripts that direct the user to the appropriate target portal or page for a specific entity such as an account or service point. Refer to
Creating Application Links in External Applications in the
Application Framework Administrative User Guide for more information about creating links.
Note: When creating application links, the use of the following parameters will help speed up launching the target page
• initNav=false: skips launching the default home page for the user
• minDashboard=true minimizes the dashboard for the user
GoTo Portal Script
The Framework provides a generic script (F1-GoToPrtl) that can be used to navigate to the maintenance portal for a specified maintenance object and entity. Refer to
Navigating to a Given Record’s Maintenance Portal in the
Application Framework Administrative User Guide for more information about using this script.
WAM Examples
The table below provides examples of using the F1-GoToPrtl script to open specific portals used by Oracle Utilities Work and Asset Management.
Script | MO | ID | Example |
F1-GoToPrtl | mo=W1-ACT | Activity ID | &script=F1-GoToPrtl&mo=W1-ACT&pkValue1={your Activity ID} |
F1-GoToPrtl | mo=W1-ASSET | Asset ID | &script=F1-GoToPrtl&mo=W1-ASSET&pkValue1={your Asset ID} |
F1-GoToPrtl | mo=W1-NODE | Location ID | &script=F1-GoToPrtl&mo=W1-NODE&pkValue1={your Location ID} |
F1-GoToPrtl | mo=W1-WORKORDER | Work Order ID | &script=F1-GoToPrtl&mo=W1-WORKORDER&pkValue1={your Work Order ID} |
Full URL Example:
https://<ENV_BASE_URL>/ouaf/cis.jsp/?minDashboard=true&initNav=false&script=F1-GoToPrtl&mo=W1-ACT&pkValue1={your Activity ID}
Parent topic
