Default Labor Requirements
A default set of labor requirements can be defined for each type of activity performed by the company. The system then uses this information to schedule activities of a certain type to the crew shift having the skills to complete the work.
Default labor requirements are defined on the activity type and include the following definitions:
Craft typically indicates a special skill, such as electrician, mechanic, and so on.
Quantity refers to the number of each craft that is needed to work the activity.
Hours refer to the time requirement to work the activity for each craft.
