Defining Change Request Types
The Change Request Type portal is used to display and maintain change request types.
You can access the portal from Admin, select C, then select Change Request Type.
• Change Request Type List: This zone lists all change type records. Broadcast a record to display the details of the selected record.
• Change Request Type: This zone provides general information about the selected change request type as well as valid approval profiles.
Parent topic
