Defining Configuration Types
The Configuration Type portal is used to display and maintain configuration types.
You can access the portal from Admin, select C, then select Configuration Type. You are brought to a query portal with options for searching for a specific configuration type. Once the configuration type has been selected, you are brought to the maintenance portal to view and maintain the selected record.
• Configuration Type List: This zone lists all configuration type records. Broadcast a record to display the details of the selected record.
• Configuration Type: This zone displays required information for various asset configurations, such as asset to asset, asset to components, and so on.
Parent topic
