Defining Crew Shift Types
The Crew Shift Type portal is used to display and maintain crew shift types.
You can access the portal from Admin, select C, then select Crew Shift Type.
• Crew Shift Type List: This zone lists all crew shift type records. Broadcast a record to display the details of the selected record.
• Crew Shift Type: This zone provides information about the selected crew shift type.
Parent topic
