Executing the Tools
To create and execute a new/custom tool:
1. Open the ArcMap or ArcCatalog application.
2. In the Catalog window, navigate to Toolboxes and then click My Toolboxes.
3. Right-click My Toolboxes and select New and then click Toolbox.
4. Enter WAMGPTools.tbx as the toolbox name and click Enter.
5. Richt-click the new toolbox and click Add and then click Tool.
6. In the Add Tool dialog box, select WAMGIGPFF and click OK.
7. To execute the Extract_Delta_Changes tool in ArcToolbox:
◦ Select and double-click the tool.
◦ View the tool's parameters.
◦ Provide the respective inputs to the parameters:
▪ Task_Name: QueryIDs
▪ Execution_Mode: Initial
▪ Feature_Class_List
▪ Example: SDE.ZZ_wControlValve
▪ Source_Version: SDE.DEFAULT
▪ Temp_Version: Temp
▪ WKID: Well-known identifier for the target spatial reference
▪ WAM Sync Version: the version name to be created in Geodatabase to track incremental changes
▪ Example: WAMSyncVersion. Leave the remaining parameters as “NA”.
◦ Click OK to run the tool.
Parent topic
