Configuring Message Senders
This section provides guidelines for configuring the components needed to support outbound messages to the GIS system.
For WACS (OCI Cloud) environment, Http/https in the Message Sender URL should be replaced with the substitution variable @EXT_​PUB@. And the ArcGIS Server services should be served over port 443 since only port 443 will be accepted in OCI environment.
Define a message sender for each of the outbound message types associated with the GIS Integration web service category using following guidelines.
Message Sender for Work Location
Field / Context
Value
Invocation Type
Real-time
Message Class
SOAP: RHTTPSNDR (Send post messages via HTTP real-time)REST: RTJSONSNDR (Sender for real-time HTTP/JSON messages)
MSG Encoding
UTF-8 message encoding
HTTP Method
POST
Active
Yes
HTTP URL 1
The URL of the corresponding service to be provided by GIS team.
WAM REST Ex: https://xxxxxxxxxxxxx:6443/arcgis/rest/services/WAM/WorkLocations/FeatureServer/0/${pathParms}
WACS REST Ex: @EXT_​PUB@xxxxxxxxxxxxx:443/arcgis/rest/services/WAM/WorkLocations/FeatureServer/0/${pathParms}
WAM SOAP Ex: https://xxxxxxxxxxxxx:6443/arcgis/services/WAM/WorkLocations/MapServer/FeatureServer
WACS SOAP Ex: @EXT_​PUB@xxxxxxxxxxxxx:443/arcgis/services/WAM/WorkLocations/MapServer/FeatureServer
HTTP Header
REST: Content-Type:application/x-www-form-urlencoded
HTTP Header
REST: Accept:application/json
HTTP Form Data
REST: adds=@XMLMSG@
Message Sender for Asset Outbound Sync
Field/Context
Value
Invocation Type
Real-time
Message Class
SOAP : RHTTPSNDR (Send post messages via HTTP real-time) REST: RTJSONSNDR (Sender for real-time HTTP/JSON messages)
MSG Encoding
HTTP Method
POST
Active
Yes
HTTP URL 1
WAM REST Ex: https://xxxxxxxxxxxxx:6443/arcgis/rest/services/WAM/DistributionNetwork/FeatureServer/${pathParms}
WACS REST Ex: @EXT_​PUB@xxxxxxxxxxxxx:443/arcgis/rest/services/WAM/DistributionNetwork/FeatureServer/${pathParms}
WAM SOAP Ex: https://xxxxxxxxxxxxx:6443/arcgis/services/WAM/DistributionNetwork/MapServer/FeatureServer
WACS SOAP Ex: @EXT_​PUB@xxxxxxxxxxxxx:443/arcgis/services/WAM/DistributionNetwork/MapServer/FeatureServer
HTTP Header
HTTP Header
HTTP Form Data
REST: Edits=@XMLMSG@
Message Sender for Asset Inbound Sync
This communication supports REST protocol only.
Field / Context
Value
Invocation Type
Real-time
Message Class
MSG Encoding
HTTP Method
POST
Active
Yes
HTTP URL 1
WAM REST Ex: https://xxxxxxxxxxxxx:6443/arcgis/rest/services/WAM/ExtractDeltaChanges/GPServer/${pathParms}
WACS REST Ex: @EXT_​PUB@xxxxxxxxxxxxx:443/arcgis/rest/services/WAM/ExtractDeltaChanges/GPServer/${pathParms}
HTTP Header
HTTP Header
Message Sender for Token Generation
This configuration is required only if the underlying map service published in ArcGIS Server are secured.This communication supports REST protocol only.
Field / Context
Value
Invocation Type
Real-time
Message Class
MSG Encoding
HTTP Method
POST
Active
Yes
HTTP URL 1
WAM REST Ex: https://xxxxxxxxxxxxx:6443/arcgis/rest/services/WAM/GenerateToken/GPServer/${pathParms}
WACS REST Ex: @EXT_​PUB@xxxxxxxxxxxxx:443/arcgis/rest/services/WAM/GenerateToken/GPServer/${pathParms}
HTTP Header
HTTP Header
