Understanding GIS Integration
GIS applications are widely used to manage assets, locations, and other spatial data. Oracle Utilities Work and Asset Management supports an integration with ESRI ArcGIS that includes data synchronization between the systems and a GIS map viewer that allows users to view asset layers on a map, create work related to these assets, and more.
This integration requires several installation steps to be performed in Esri ArcGIS. Refer to the Installation Guide for more information.
The following sections describe concepts and configuration options related to GIS integration.
Parent topic
