Maintaining Operational Readings
The Operational Reading portal is used to display and maintain an operational read record.
You can access the portal from Menu, select Asset Management, and then select Operational Reading. You are brought to a query portal with options for searching for a specific operational read. Once the read has been selected, you are brought to the maintenance portal to view and maintain the selected record.
• Measurement: This zone displays information about the operational reading.
• Measurement Activity: This zone lists the measurement activities associated with the operational reading.
Parent topic
