Maintaining Service History
This portal is used to display and maintain service history records.
Refer to
About Service History for more information.
You can access the portal from the Menu, select Asset Management, then select Service History. You are brought to a query portal with options for searching for a specific service history. Once a service history has been selected, you are brought to the maintenance portal to view and maintain the selected record.
• Service History: This zone supplies details about the service history for an asset.
• Attachments: This zone enables users to manage all types of attachments for the service history record.
Parent topic
