Understanding System Messages
All error, warning and informational messages that are displayed in the system are maintained on the message table. Every message is identified by a combination of two fields:
Message category number. Think of a message category as a library of messages related to a given functional area. For example, there is a message category for billing messages and another one for payment messages.
Message number. A unique number identifies each message within a category.
Every message has two components: a brief text message and a long description.
Note:You cannot change the product’s text. If the message is "owned" by the product, you cannot change the product’s message or detailed description. If you want your users to see a different message or detailed description other than that supplied by the product, enter your desired verbiage in the corresponding override fields (and flush the cache).
