Captured Information
When auditing is enabled for a field, the following information is recorded when the field is changed, added and/or deleted (depending on the actions that you are auditing for that field):
User ID
Date and time
Table name
Row's prime key value
Field name
Before image (blank when a row is added)
After image (blank when a row is deleted)
Row action (add, change, delete)
