Defining Web Service Categories
Refer to
Web Service Category for an overview of this functionality.
Use this page to define basic information about a web service category. Open this page using > > You are brought to a query portal with options for searching for web service categories.
This page is not available if the
External Message module is
turned off.
Once a web service category has been selected, you are brought to the maintenance portal to view and maintain the selected record.
The Web Service Category zone provides basic information about a web service category.
CAUTION:
Important! When adding new records, carefully consider the naming convention of the web service category code. Refer to
System Data Naming Convention for more information.
Once a web service category exists, an Add Web Services zone is provided to find and select web services to link to the web service category.
When viewing a category that already has web services linked to it, they are visible in the zone Included Web Services . This zone allows a user to remove a customer owned web service from the list.
Parent topic
