Standard Name Lookup
Navigate to the Extendable Lookup portal. Search for and select the External Insights Standard Name business object.
Define values that are recognized in the external systems that your implementation is receiving business flag details from.
Define a Category for the standard name that is appropriate for your product. Note that the category does not have to be in sync with standard name definitions in external products.
Select a Class for the standard name that is appropriate for its usage.
Refer to the embedded help for more information about configuring this object.
