Defining Communication Types
The Communication Type portal is used to display and maintain communication types.
You can access the portal from Admin, select C, then select Communication Type.
Communication Type List: This zone lists all communication type records. Broadcast a record to display the details of the selected record.
Communication Type: This zone provides information about the selected communication type, such as attachment suppression, communication data mapping, message validation and exception handling.
