Defining Configurations
The Configuration portal is used to display and maintain configurations.
You can access the portal from Admin, select C, and then select Configuration. You are brought to a query portal with options for searching for a specific configuration. Once the configuration has been selected, you are brought to the maintenance portal to view and maintain the selected record.
Configuration: This zone provides information about the configuration, such as asset and specification details.
Attachments: This zone displays attachments related to the specific record.
