Defining Employees
The Employee portal is used to display and maintain employees.
You can access the portal from Admin, select E, then select Employee. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
Employee: This zone provides information about the employee, such as personal information, employment information, training information, and payroll information.
Employee Assets: This zone identifies the relationship types between assets and employee.
Employee Shifts: This zone provides a calendar view of employee shifts.
Billable Rate: This zone provides hourly rate and effective date information for the selected employee.
The following zones may appear as part of the portal's Timesheet Schedule tab page:
Timesheet Schedule: This zone enables or disables the automatic generation of timesheet rows for an individual employee. Also, timesheet and scheduling information can be edited directly from this zone.
