Defining Failure Repairs
The Failure Repair portal is used to display and maintain failure repairs.
You can access the portal from Admin, select F, then select Failure Repair.
Failure Repair List: This zone lists all failure repair records. Broadcast a record to display the details of the selected record.
Failure Repair: This zone identifies the repair that will be made to the failed asset.
Included on Failure Profile: This zone lists the failure profiles associated with a particular failure repair.
