Defining Measurement Types
The Measurement Type portal is used to display and maintain measurement types.
You can access the portal from Admin, select M, then select Measurement Type.
Measurement Type List: This zone lists all measurement type records. Broadcast a record to display the details of the selected record.
Measurement Type: This zone provides information about the selected measurement type, including upper and lower threshold limits and inner and outer threshold exceeded details.
