Configuring Outbound Messages in External System
External System for Work Location and Asset Outbound Sync
Configure an external system record for the GIS system your company sends messages to. Refer to External System for more information.
Provide an entry for each of the outbound message types associated with the GIS Integration web service category following these guidelines:
Field
Value
Outbound Message Type
The provided outbound message type
Processing Method
Real-time
Message Sender
The corresponding message sender for this type of message
Date/Time Format
XSD
JSON Conversion Method
REST: XSL Transformation
Message XSL
SOAP: W1-CommonGISRequestForSOAP.xslREST: W1-CommonGISRequestForREST.xsl
Response XSL
SOAP: W1-CommonGISResponseForSOAP.xsl
REST: W1- CommonGISResponseForREST.xsl (for WAM if File System is used for XSL files)
REST: W1-CommonGISRespForREST.xsl (for WACS if Managed Content is used for XSL files)
External System for Asset Inbound Sync and Token Generation
Field
Value
Processing Method
Real-time
Message Sender
Date/Time Format
XSD
XSL Transformation
Response XSL
W1–GISAssetInbound.xsl
