Maintaining Warranty Terms
The Warranty Term portal is used to display and maintain a warranty term record.
You can access the portal from Menu, select Asset Management, and then select Warranty Term. You are brought to a query portal with options for searching for a specific warranty term record. Once a warranty term has been selected, you are brought to the maintenance portal to view and maintain the selected record.
Warranty Term: This zone displays information about the terms of the warranty.
Warranty: This zone lists information about the warranty and associated asset.
Attachments: This zone enables users to manage all types of attachments for the warranty term record.
