Scheduling Portal
This portal helps planners manage craft capacities and activity labor requirements for crew shifts.
You can access this portal from Menu, select Work Management, and then select Scheduling. You are brought to a query portal with options for searching for a specific crew shift. Once the crew shift has been selected, you are brought to the Scheduler portal where you can view and manage the craft capacities and labor requirements for the selected record.
The following zones may appear as part of the portals Main tab page:
Craft Capacity. This zone displays a graphical representation of the various crafts, craft capacities, and remaining hours for the particular crew shift.
Activity Search. This zone displays a query portal with options for searching for activities.
Scheduled Labor Requirements. This zone displays the work activity, labor requirements, and crew allocation associated with the crew shift.
Refer to About Scheduling for more information.
