Importing Controllable Devices
This topic provides additional details related to importing legacy controllable devices from a demand response management system (DRMS) into Digital Asset Management / Digital Asset Cloud Service.
Controllable Device Import File Format
Legacy controllable device import files use the following tab-separated values format:
Field Name |
Optional/Required |
Notes |
Legacy Device Id |
Required |
An id for the controllable device in the DRMS application. |
Device Type |
Required |
The controllable device's type. This must be a valid controllable device type defined in Digital Asset Management / Digital Asset Cloud Service. See Understanding Controllable Asset Types for more information. |
Serial Number |
Optional |
The controllable device's serial number. |
Badge Number |
Optional |
The controllable device's badge number. |
NIC ID |
Required |
The controllable device's Network Identification Card (NIC) ID. |
Head End Registration |
Optional |
A flag that indicates if the controllable device is registered in the head end system. Valid values are values for the Head-End Registration Status (HEAD_END_REGISTR_STATUS_FLG) lookup, and include:
Legacy Device Date Time |
Required |
The controllable device's asset disposition date and time. This will be one of the following:
Specification |
Required |
The specification associated with the controllable device. This must be a specification defined in Digital Asset Management / Digital Asset Cloud Service |
Asset Ownership |
Optional |
A flag that indicates the controllable device's ownership. Valid values are values for the Asset Ownership (ASSET_OWNERSHIP_FLG) lookup, and include:
Asset Status |
Required |
A value that indicates the current status of the controllable device. Valid values include:
Sample Record
Below is a sample file:
EXTDVC3 ZZ-MUYU SERIALNBR3 BADGENBR3 NICID3 D1NR 2023-04-23T12:22:00-05:00 ZZ-MUYU-CD-SPEC W1CO INSTORE
Upload Batch Process
Legacy controllable device import files are uploaded using the Legacy Controllable Device File Upload (X1-DVUPL) batch process. Use the Batch Control portal to view the parameters used by this batch process. This process should be run as needed for the initial import.
This process creates inbound sync requests in the "Pending" state (see below).
Inbound Sync Request Business Object
Controllable device inbound sync requests are based on the Controllable Device Initial Sync Request (X1-DASyncReqControllableDevice) business object.
Inbound sync requests are created in the "Pending" state. The Sync Request Monitor (F1-SYNRQ) batch process is used to transition these to the "Transform/Validate" state where the data is validated and transformed as needed for import and moved into the "Validated" state (or "Validation Error" if an error is encountered). These are processed by an "Initial Sync Request Load" batch process (see below).
Initial Sync Request Load Batch Process
Legacy controllable devices are created from inbound sync requests using the Initial Sync Request - Load Controllable Device (X1-SILDV) batch process. Use the Batch Control portal to view the parameters used by this batch process. This process should be run as needed for the initial import.
This process transitions the inbound sync requests to the "Loaded" state.
Create Controllable Asset from Controllable Device Batch Process
The Create Controllable Asset from Controllable Device (X1-CRAST) batch control is used to create controllable assets from newly uploaded controllable devices. This process should be run as needed for the initial import.
This process uses the following algorithms:
Select Records - Controllable Devices without an asset id (X1-SLNOASSET): This algorithm selects controllable devices where the legacy device ID is populated, but the Asset ID is empty.
Process Record - Create Controllable Asset - DACS (X1CREATASSET): This algorithm creates controllable assets from data in the Controllable Device Initial Sync Request (X1-DASyncReqControllableDevice) inbound sync requests created for each controllable device.
This process uses the following parameters:
Default Out of Service Location: The fallback out of service location used when creating controllable assets if other state-specific out of service locations are not defined. (Required) Note that controllable asset types must be configured with the appropriate device location types for each these states. See Understanding Controllable Asset Types for more information.
In Store Out of Service Location: The out of service location when creating controllable assets in the "In Store" state.
InRepair Out of Service Location: The out of service location when creating the controllable assets in the "In Repair" state.
Retired Out of Service Location: The out of service location when creating the controllable assets in the "In Store", "In Repair" or "Retired" state.
Use the Batch Control portal to learn more about these and other parameters used by these batch process.
