Defining Contact Types
The Contact Type portal is used to display and maintain contact types.
Refer to Understanding Contact Types for more information.
You can access the portal from Admin, select C, then select Contact Type. You are brought to the contact type list page.
- Contact Type List: This zone lists all contact types. Broadcast a record to display the details for the selected record.
- Contact Type: This zone displays information about the selected contact type.
