System Table List
This section contains names of system tables, upgrade actions, and a brief description of tables. The upgrade actions are explained below.
Keep (KP): The data in the table in the customer's database is kept untouched. No insert or delete is performed to this table by the upgrade process. The initial installation will add necessary data for the system
Merge (MG): The non-base product data in the table in the database is kept untouched. If the data belongs to the base product, any changes pertaining to the new version of the software are performed.
Refresh (RF): The existing data in the table is replaced with the data from the base product table. The product does not support customer specific data in these tables.
Note. New product data is also inserted into tables marked as 'Merge'. If implementers add rows for a customer specific enhancement, it can cause duplication when the system data gets upgraded to the next version. We strongly recommend following the guidelines on how to use designated range of values or prefixes to segregate the implementation data from the base product data.
Table Name
Upgrade
Action
Description
CI_ALG
MG
Algorithm
CI_ALG_L
MG
Algorithm Language
CI_ALG_PARM
MG
Algorithm Parameters
CI_ALG_TYPE
MG
Algorithm Type
CI_ALG_TYPE_L
MG
Algorithm Type Language
CI_ALG_TYPE_PRM
MG
Algorithm Type Parameter
CI_ALG_TYPE_PRM_L
MG
Algorithm Type Parameter Language
CI_ALG_VER
MG
Algorithm Version
CI_APP_SVC_ACC
MG
Application Service Access Mode
CI_BATCH_CTRL
MG
Batch Control
CI_BATCH_CTRL_ALG
MG
Batch Control Algorithm
CI_BATCH_CTRL_L
MG
Batch Control Language
CI_BATCH_CTRL_P
MG
Batch Control Parameters
CI_BATCH_CTRL_P_L
MG
Batch Control Parameters Language
CI_CHAR_ENTITY
MG
Characteristic Type Entity
CI_CHAR_TYPE
MG
Characteristic Type
CI_CHAR_TYPE_L
MG
Characteristic Type Language
CI_CHAR_VAL
MG
Characteristic Type Value
CI_CHAR_VAL_L
MG
Characteristic Type Value Language
CI_DISP_ICON
MG
Display Icon
CI_DISP_ICON_L
MG
Display Icon Language
CI_FK_REF
MG
Foreign Key Reference
CI_FK_REF_L
MG
Foreign Key Reference Language
CI_LANGUAGE
MG
Language Code
CI_LOOKUP_FIELD
MG
Lookup Field
CI_LOOKUP_VAL
MG
Lookup Field Value
CI_LOOKUP_VAL_L
MG
Lookup Field Value Language
CI_MD_CONST
MG
Constraints
CI_MD_CONST_FLD
MG
Constraint Fields
CI_MD_FLD
MG
Field
CI_MD_FLD_L
MG
Field Language
CI_MD_MENU
MG
Menu Information
CI_MD_MENU_IMOD
MG
Menu Item Module Maint
CI_MD_MENU_ITEM
MG
Menu Item
CI_MD_MENU_ITEM_L
MG
Menu Item Language
CI_MD_MENU_L
MG
Menu Language
CI_MD_MENU_LINE
MG
Menu Line
CI_MD_MENU_LINE_L
MG
Menu Line Language
CI_MD_MENU_MOD
MG
Menu Product Components
CI_MD_MO
MG
Maintenance Object
CI_MD_MO_ALG
MG
Maintenance Object Algorithm
CI_MD_MO_L
MG
Maintenance Object Language
CI_MD_MO_OPT
MG
Maintenance Object Option
CI_MD_MO_TBL
MG
Maintenance Object Table
CI_MD_MO_WRK
MG
Maintenance Object Work Tables
CI_MD_NAV
MG
Navigation Key
CI_MD_PRG_COM
MG
Program Components
CI_MD_PRG_ELEM
MG
UI Page Elements
CI_MD_PRG_EL_AT
MG
UI Page Element Attributes
CI_MD_PRG_LOC
MG
Program Location
CI_MD_PRG_MOD
MG
Program Module
CI_MD_PRG_SEC
MG
UI Page Sections
CI_MD_PRG_SQL
MG
MD SQL Meta Data
CI_MD_PRG_TAB
MG
UI Tab Meta Data
CI_MD_PRG_VAR
MG
Program Variable
CI_MD_SO
MG
Search Object
CI_MD_SOCG
MG
Search Object Criteria Group
CI_MD_SOCG_FLD
MG
Search Object Criteria Group Field
CI_MD_SOCG_FLDAT
MG
Search Criteria Group Field Attribute
CI_MD_SOCG_L
MG
Search Object Criteria Group Language
CI_MD_SOCG_SORT
MG
Search Criteria Group Result Sort Order
CI_MD_SO_L
MG
Search Object Language
CI_MD_SO_RSFLD
MG
Search Object Result Field
CI_MD_SO_RSFLDAT
MG
Search Object Result Field Attribute
CI_MD_SVC
MG
MD Service
CI_MD_SVC_L
MG
MD Service Language
CI_MD_SVC_PRG
MG
MD Service Program
CI_MD_TAB_MOD
MG
UI Tab Module
CI_MD_TBL
MG
MD Table
CI_MD_TBL_FLD
MG
MD Table Field
CI_MD_TBL_FLD_L
MG
MD Table Field Language
CI_MD_TBL_L
MG
MD Table Language
CI_MD_WRK_TBL
MG
Work Table
CI_MD_WRK_TBLFLD
MG
Work Table Field
CI_MD_WRK_TBL_L
MG
Work Table Language
CI_MSG
MG
Message
CI_MSG_CATEGORY
MG
Message Category
CI_MSG_CATEGORY_L
MG
Message Category Language
CI_MSG_L
MG
Message Language
CI_NAV_OPT
MG
Navigation Option
CI_NAV_OPT_CTXT
MG
Navigation Option Context
CI_NAV_OPT_L
MG
Navigation Option Language
CI_NAV_OPT_USG
MG
Navigation Option Usage
CI_PORTAL
MG
Portal
CI_PORTAL_L
MG
Portal Language
C1_PORTAL_OPT
MG
Portal Option
CI_PORTAL_ZONE
MG
Portal Zone
CI_SCR
MG
Script
CI_SCR_CRT
MG
Script Criteria
CI_SCR_CRT_GRP
MG
Script Criteria Group
CI_SCR_CRT_GRP_L
MG
Script Criteria Group Language
CI_SCR_DA
MG
Script Data Area
CI_SCR_FLD_MAP
MG
Script Field Mapping
CI_SCR_L
MG
Script Language
CI_SCR_PRMPT
MG
Script Prompt
CI_SCR_PRMPT_L
MG
Script Prompt Language
CI_SCR_STEP
MG
Script Step
CI_SCR_STEP_L
MG
Script Step Language
CI_SEQ
MG
Sequence
CI_TD_DRLKEY_TY
MG
To Do Type Drill Key
CI_TD_SRTKEY_TY
MG
To Do Type Sort Key
CI_TD_SRTKEY_TY_L
MG
To Do Type Sort Key Language
CI_TD_TYPE
MG
To Do Type
CI_TD_TYPE_L
MG
To Do Type Language
CI_UI_ZONE
MG
Context Sensitive Zone
CI_USR_NAV_LINK
MG
User Favorite Links
CI_XAI_ADAPTER
MG
XAI Adapter
CI_XAI_ADAPTER_L
MG
XAI Adapter Lang
CI_XAI_CLASS
MG
Message Class
CI_XAI_CLASS_L
MG
Message Class Language
CI_XAI_ENV_HNDL
MG
XAI Envelope Handler
CI_XAI_ENV_HNDL_L
MG
XAI Envelope Handler Language
CI_XAI_IN_SVC
MG
XAI Inbound Service
CI_XAI_IN_SVC_L
MG
XAI Inbound Service Language
CI_XAI_SVC_PARM
MG
XAI Inbound Service Parameters
CI_ZONE
MG
Zone
CI_ZONE_HDL
MG
Zone Type
CI_ZONE_HDL_L
MG
Zone Type Language
CI_ZONE_HDL_PRM
MG
Zone Type Parameters
CI_ZONE_HDL_PRM_L
MG
Zone Type Parameters Language
CI_ZONE_L
MG
Zone Language
CI_ZONE_PRM
MG
Zone Parameters
F1_BUS_OBJ
MG
Business Object
F1_BUS_OBJ_ALG
MG
Business Object Algorithm
F1_BUS_OBJ_L
MG
Business Object Language
F1_BUS_OBJ_OPT
MG
Business Object Option
F1_BUS_OBJ_STATUS
MG
Business Object Status
F1_BUS_OBJ_STATUS_ALG
MG
Business Object Status Algorithm
F1_BUS_OBJ_STATUS_L
MG
Business Object Status Language
F1_BUS_OBJ_STATUS_OPT
MG
Business Object Status Option
F1_BUS_OBJ_STATUS_RSN
MG
Status Reason
F1_BUS_OBJ_STATUS_RSN_L
MG
Status Reason Language
F1_BUS_OBJ_TR_RULE
MG
Business Object Transition Rule
F1_BUS_OBJ_TR_RULE_L
MG
Rule Language
F1_BUS_SVC
MG
Business Service
F1_BUS_SVC_L
MG
Business Service Language
F1_DATA_AREA
MG
Data Area
F1_DATA_AREA_L
MG
Data Area Language
F1_DB_OBJECTS_REPO
MG
Database Objects Repository
F1_DEPLOYMENT_ITEM
MG
Deployment Part Item
F1_DEPLOYMENT_PART
MG
Deployment Part
F1_DEPLOYMENT_PART_L
MG
Deployment Part Language
F1_EXT_LOOKUP_VAL
MG
Extendable Lookup
F1_EXT_LOOKUP_VAL_L
MG
Extendable Lookup Language
F1_EXT_LOOKUP_VAL_CHAR
MG
Extendable Lookup Characteristics
F1_IWS_ANN
MG
Web Service Annotation
F1_IWS_ANN_L
MG
Web Service Annotation Language
F1_IWS_ANN_PARM
MG
Web Service Annotation Parameter
F1_IWS_ANN_TYPE
MG
Web Service Annotation Type
F1_IWS_ANN_TYPE_L
MG
Type Language
F1_IWS_ANN_TYPE_PARM
MG
Web Service Annotation Type Parm
F1_IWS_ANN_TYPE_PARM_L
MG
Parameter Language
F1_IWS_SVC
MG
Inbound Web Service
F1_IWS_SVC_L
MG
Inbound Web Service Language
F1_IWS_SVC_OPER
MG
Inbound Web Service Operations
F1_IWS_SVC_OPER_PARM
MG
Inbound Web Service Operations Parameter
F1_MKTCFG
MG
Market Configuration
F1_MANAG_CONTENT
MG
Managed Content
F1_MANAG_CONTENT_L
MG
Managed Content Language
F1_MAP
MG
UI Map
F1_MAP_L
MG
UI Map Language
F1_MIGR_PLAN
MG
Migration Plan
F1_MIGR_PLAN_INSTR
MG
Migration Plan Instruction
F1_MIGR_PLAN_INSTR_ALG
MG
Migration Plan Instruction Algorithm
F1_MIGR_PLAN_INSTR_L
MG
Migration Plan Instruction Language
F1_MIGR_PLAN_L
MG
Migration Plan Language
F1_MIGR_REQ
MG
Migration Request
F1_MIGR_REQ_INCL_REQ
MG
Migration Request Grouping
F1_MIGR_REQ_INSTR
MG
Migration Request Instruction
F1_MIGR_REQ_INSTR_
ENTITY
MG
Migration Request
Instruction Entity
F1_MIGR_REQ_INSTR_L
MG
Migration Request
F1_MIGR_REQ_L
MG
Migration Request Language
F1_MOBILE_COMPONENT
MG
Mobile Component
F1_MOBILE_COMPONENT_L
MG
Mobile Component Language
F1_MOB_COMP_CHAR
MG
Mobile Component Characteristics
F1_MOB_COMP_CNT
MG
Mobile Component Content
F1_OUTMSG_TYPE
MG
Outbound Message Type
F1_OUTMSG_TYPE_L
MG
Outbound Message Type Language
F1_PROC_DEFN
MG
Process Flow Type
F1_PROC_DEFN_L
MG
Process Flow Type Language
F1_PROC_NEXT_PANEL
MG
Next Panel
F1_PROC_PANEL
MG
Process Panels
F1_SCHEMA
MG
Schema
F1_WEB_CAT
MG
Web Service Category
F1_WEB_CAT_L
MG
Web Service Category Language
F1_WEB_CAT_INCL_SVC
MG
Web Service Category Included Services
F1_FILE_INT_REC
MG
File Integration Record Table
F1_FILE_INT_REC_L
MG
File Integration Record Language Table
F1_FILE_INT_REC_ALG
MG
File Integration Record Algorithm Table
F1_FILE_INT_TYPE
MG
File Integration Type
F1_FILE_INT_TYPE_L
MG
File Integration Language Table
F1_MD_BI_TBL
MG
MD Table for BI
F1_MD_BI_TBL_L
MG
MD Language Table for BI
F1_MD_BI_TBL_FLD
MG
MD Field Table for BI
SC_ACCESS_CNTL
MG
User Group Access Control
SC_APP_SERVICE
MG
Application Service
SC_APP_SERVICE_L
MG
Application Service Language
SC_USR_GRP_PROF
MG
User Group Profile
CI_CURRENCY_CD
KP
Currency Code
CI_CURRENCY_CD_L
KP
Currency Code Language
CI_DISP_PROF
KP
Display Profile
CI_DISP_PROF_L
KP
Display Profile Language
CI_TIME_ZONE
KP
Time Zone
CI_TIME_ZONE_L
KP
Time Zone Language
CI_USR_PORTAL
KP
User Portal
CI_XAI_JNDI_SVR
KP
XAI JNDI Server
CI_XAI_JNDI_SVR_L
KP
XAI JNDI Server Language
CI_XAI_OPTION
KP
Message Option
CI_XAI_SENDER
KP
Message Sender
CI_XAI_SENDER_L
KP
Message Sender Language
CI_XAI_SNDR_CTX
KP
Message Sender Context
CHAR
KP
Status Reason Characteristic
F1_INSTALLATION
KP
Installation Option - Framework
SC_USER
KP
User
SC_USER_CHAR
KP
User Characteristic
SC_USER_GROUP
KP
User Group
SC_USER_GROUP_L
KP
User Group Language
SC_USR_GRP_USR
KP
User Group User
CI_MD_ATT_TY
RF
MD Element Attribute Type
CI_MD_AT_DTL
RF
MD Element Attribute Type Detail
CI_MD_AT_DTL_L
RF
MD Element Attribute Type Detail Language
CI_MD_CTL
RF
Generator Control
CI_MD_CTL_L
RF
Generator Control Language
CI_MD_CTL_TMPL
RF
Generator Control Template
CI_MD_ELTY
RF
MD Element Type
CI_MD_ELTY_AT
RF
Element Type Attributes
CI_MD_ELTY_L
RF
Element Type Language
CI_MD_LOOKUP_F
RF
MD Lookup Field
CI_MD_MSG
RF
MD Message
CI_MD_MSG_L
RF
MD Message Language
CI_MD_PDF
RF
Predefined Fields
CI_MD_PDF_VAL
RF
Predefined Values
CI_MD_SRC_TYPE
RF
Source Type
CI_MD_SRC_TYPE_L
RF
Source Type Language
CI_MD_TMPL
RF
Template
CI_MD_TMPL_ELTY
RF
Template Element Types
CI_MD_TMPL_L
RF
Template Language
CI_MD_TMPL_VAR
RF
Template Variable
CI_MD_TMPL_VAR_L
RF
Template Variable Language
CI_MD_VAR
RF
Variable
CI_MD_VAR_DTL
RF
Variable Detail
CI_MD_VAR_DTL_L
RF
Variable Detail Language
CI_XAI_EXECUTER
RF
XAI Executer
CI_XAI_EXECUTER_L
RF
XAI Executer Language
CI_XAI_FORMAT
RF
XAI Format
CI_XAI_FORMAT_L
RF
XAI Format Language
F1_LGCY_OBJ
RF
Unsupported Metadata
