Upgrade Paths
The following upgrade paths are supported:
• from V2.2.0.6.0 to V2.4.0.0.0
• from V2.3.0.0.0 to V2.4.0.0.0
Note: Before you can upgrade you must have a prior version installed. Otherwise, you should follow the procedures described in the
Initial Installation Procedure section of the
Oracle Utilities Work and Asset Management Installation Guide.
