Product | Sub Product | Licensing Description |
Oracle Utilities Work and Asset Management | Oracle Utilities Work and Asset Management Enterprise Edition | Oracle Utilities Work and Asset Management Enterprise Edition contains a set of processes to support asset, work, construction work, purchasing and inventory management. Oracle Utilities Work and Asset Management and Oracle Utilities Operational Device Management are built upon a common asset management architecture. Both products include functionality which must be licensed correctly in order to be used. The table below provides information about these functional areas. Prerequisites: • Oracle Database Enterprise Edition • Oracle WebLogic Server Enterprise Edition Restrictions: Licensing restrictions are only enforced within the application using application services and user access roles. While it is possible for administrators to enable non licensed functionality, use of this functionality without a license is prohibited. The Purchase Requisition portal is included in Enterprise Edition. Read-only access is provided for the remaining Purchasing portals as part of this license without the Oracle Utilities Work and Asset Management Purchasing license. For read/write access to these Purchasing portals Oracle Utilities Work and Asset Management Purchasing must be licensed separately. |
Oracle Utilities Work and Asset Management Purchasing | Oracle Utilities Work and Asset Management Purchasing provides a comprehensive set of Purchasing processes to enhance Oracle Utilities Work and Asset Management Enterprise Edition. Prerequisites: • Oracle Utilities Work and Asset Management Enterprise Edition | |
Oracle Utilities Work and Asset Management Construction Work Management | Oracle Utilities Work and Asset Management Construction Work Management provides a comprehensive set of processes to facilitate the management of construction work. Prerequisites: • Oracle Utilities Work and Asset Management Enterprise Edition | |
Oracle Utilities Work and Asset Management Connector for Enterprise Resource Planning | Oracle Utilities Work and Asset Management Connector for Enterprise Resource Planning provide a suite of integration APIs and Enterprise Business Objects to assist with integration to external applications. These connectors are specifically designed to assist with integration to Enterprise Resource Planning (ERP) applications but can be used for integration to any external application. Purchase of the Oracle Utilities Work and Asset Management Connector for Enterprise Resource Planning includes read-only access to the Purchasing modules. This allows ERP clients to see the data that they load with the ERP connector. Additionally, this connector includes a series of work order APIs which can be used for integration to the Work Order Activity portal. When using the work order APIs for connecting to 3rd party mobile applications where field workers will need to record cost charges and work order activity closeout information, the 'Oracle Utilities Work and Asset Management 3rd Party Mobile Connector' is required for each field resource. Prerequisites: • Oracle Utilities Work and Asset Management Enterprise Edition • Oracle SOA Suite (Application specific technology license can be used) | |
Oracle Utilities Work and Asset Management Connector for Geospatial Information Systems | Oracle Utilities Work and Asset Management Connector for Geospatial Information Systems provide the ability to connect Oracle Utilities Work and Asset Management to the ESRI geospatial information system (GIS) application to enable the ability to view work and asset management information using the ESRI GIS viewer. Prerequisites: • Oracle Utilities Work and Asset Management Enterprise Edition | |
Process Integration Pack for Oracle Utilities Field Work | The Process Integration Pack for Oracle Utilities Field Work supports the creation and synchronization of field work activities between Oracle Utilities Mobile Workforce Management and Oracle Utilities Work and Asset Management. Prerequisites: • Oracle Utilities Work and Asset Management Enterprise Edition | |
Oracle Utilities Work and Asset Management 3rd Party Mobile Connector | Provides access to WAM data on a 3rd party mobile device Prerequisites: Oracle Utilities Work and Asset Management Enterprise Edition Restrictions: Licensed users of "Oracle Field Service Cloud Service: Base Parts" option do not require the "Oracle Utilities Work and Asset Management 3rd Party Mobile Connector' license if they're only accessing the Oracle Utilities Work and Asset Management application via these mobile applications. All 3rd party mobile users accessing the Oracle Utilities Work and Asset Management application must have an 'Oracle Utilities Work and Asset Management 3rd Party Mobile Connector' license. |
