Supported Integrations
The following integrations are supported in this version of Oracle Utilities Work and Asset Management 2.4.0.0.0.
Note: Version numbers listed below are supported as of the v2.4.0.0.0. release (April 2021). Refer to the Certification Matrix for Oracle Utilities Products (Document ID 1454143.1) on My Oracle Support to determine if support for newer versions of the listed products have been added.
Oracle Utilities Product Integrations to Oracle Applications
• Oracle Utilities Work and Asset Management Connector for Enterprise Resource Planning (ERP)
The Oracle Utilities Work and Asset Management Connector for Enterprise Resource Planning enables integration of Oracle Utilities Work and Asset Management with a generic set of business processes and data exchanges for implementations with Enterprise Resource Planning systems such as Oracle E-Business Suite, PeopleSoft, JD Edwards EnterpriseOne, Fusion Applications or Enterprise Resource Planning Cloud.
• Oracle Utilities Work and Asset Management Integration to Oracle Field Service
• Oracle Utilities Work and Asset Management Integration to Oracle Primavera
• Oracle Utilities Work and Asset Management V2.4.0.0.0 to Oracle Utilities Analytics 2.7.0.x
• Oracle Integration Pack for Oracle Utilities Field Work V12.2
• Oracle Utilities Mobile Workforce Management V2.3.0.3+
Additional Integrations
• GIS Integration
The GIS Integration uses ESRI GIS software to allow users to view asset layers on a map, and to create and view work requests and work orders on the map.
• BI Publisher Reports Integration
BI Publisher Reports allow users to generate and print reports for certain entities, such as operational data, activity reports, purchasing reports, inventory reports and so on. Refer to the Administrative User Guide for more information.
Please refer to the Oracle Utilities Work and Asset Management Administrative User Guide or the specific integration guides available on the Oracle Technology Network for more information.
