Demo Data Information
The application delivers a demo database based on the application versions provided with the release, including Oracle Utilities Application Framework.
Demo data provides sample configuration and data for key application features. Demo data is delivered as part of the base installation. Refer to the Oracle Utilities Work and Asset Management Database Administrator’s Guide for more information, or contact Oracle Support.
Oracle recommends that you do not clone the demonstration environment as a basis for a new production environment. The demonstration environment typically includes transactional data that will be irrelevant to your production environment and can cause unexpected issues if it is not purged correctly. The recommended process is to start a new production environment from a new installation and migrate “clean” system data (such as business objects and algorithms) and administrative data (such as sample activity types or other administrative entities) from the demonstration and/or test or development environments as applicable.
Refer to the Oracle Utilities Work and Asset Management Administrative User Guide for more information or contact Oracle Support.
