Encryption Feature Type
One of the major features of the Oracle Utilities Application Framework is the ability to mask and encrypt data within Oracle Utilities Work and Asset Management to protect sensitive information. This encryption is implemented in a Feature Configuration using the Encrypted Feature Type.
The Oracle Utilities Application Framework supports Feature Configuration which store specific configuration settings for features in the product to be implemented. Feature Configurations allow simple configurations to be implemented for specific features.
Feature Configurations can be maintained using the Feature Configuration menu option on the Administration menu.
For the Encryption feature, one Feature Configuration should exist for the Encryption Feature Type with an option per field to encrypt.
Note: If the product does not ship a Feature Configuration for Encryption, then it can be created as a Customer Modification. Prefix the name of the Feature Name with CM.
