Federated Outbound Messages
Note: The Authorization Server setup and Client Setup are identical to the configuration of Inbound Web Services. Refer to
Process Flow for initial setup instructions.
Outbound Messages allows product transactions to send information out of the product via technology connectors in synchronous and asynchronous modes.
Overview
As with the Inbound Web Services the architecture of the Federated security involves issuing a token from an authorized user from the Authorization Server to the External System:
• An Outbound Message is created by the business process of a certain type and with the relevant payload.
• An External System definition with the product decides how this information is sent to the External System (the technology and mode).
• A Message Sender is configured to use the relevant policy in its context parameters to send to the external system. The policies supported are configured on an Extended Lookup to filter the policies available.
• When sending the information out, the Authorization Server issues a token to an authorized transaction to use in the transaction to the external system.
• Trust is established between the Authorization Server and Resource Server for the external system to accept valid transactions. This certificate must be exported from the Authorization Server and imported into the technology used by the Resource Server.
• For example:
![](../WAM_SECURITY_24000/images/FederatedSecurity_OutboundMessages.png)
OAuth Policies
To use this facility the following policies are recommended for use from Oracle Web Service Manager and the product:
These two policies are compatible with the
oracle/multi_token_rest_service_policy used for Inbound Web Services (REST and SOAP).
Extendable Lookup Configuration
Note: These values are shipped with the product meta data and the policy configuration values set for the policy used should refer to the Oracle Web Services Manager documentation for a description of the valid values.
The following Extended Lookups are provided to be used:
The following recommendations apply to the configuration of the above policies:
• The URI parameters may be hardcoded or use substitution variables as outlined in the Server Administration Guide. If substitution variables are used, they should be configured in the substitutionVariable.xml configuration file. For example:
<uriVariable>
<name>F1_TOKEN_URI</name>
<value>http://<server>:<port>/ms_oauth/oauth2/endpoints/oauthservice/tokens</value>
</uriVariable>
• Additional parameters may be set according the documentation for the
Client and
Token. Message Sender Configuration
The final step in the configuration of the use of federation for Outbound Messages is to configure the context of the Message Sender to use the Policy Set that was configured in the earlier step. To use the federation the following content types must be set:
