Conventions
This section contains several conventions to illustrate attributes and scope of configuration parameters:
Each parameter has certain valid values. When applicable, the default value is indicated in bold.
The scope of the parameter is indicated through the following terms for the applicable tiers
WEB
Web Application Server
BAS
Business Application Server
IWS
Inbound Web Services
DB
Database
BATCH
Background Processing
The ordinality of the parameter is indicated. Parameters that are mandatory must exist and are set in the relevant configuration file for the product to operate.
