Discovering Oracle Utilities Targets
Prior to using Oracle Enterprise Manager, the Oracle Utilities targets must be discovered and registered with the Oracle Management Repository (OMR) within an Oracle Management Server (OMS) using Oracle Management Agents (OMA).
To discover the Oracle Utilities targets the following process must be followed:
• Install the Oracle Management Server and Oracle Management Repository to the relevant centralized server in accordance with the Oracle Enterprise Manager documentation.
Note: It is not recommended to install the Oracle Management Server or Oracle Management Repository on the same servers housing the products.
• Deploy the Oracle Management Agents to the hosts housing the products.
• Discover and register the hosts and agents to the Oracle Management Repository using any of the methods described in the Oracle Enterprise Manager documentation.
• Start the products using the console or scripts.
Note: Oracle Enterprise Manager will only discover and register targets that are active at the time of discovery.
• Deploy the base Fusion Middleware functionality to the agents on the hosts for the products.
• Discover the Fusion Middleware targets associated with the product. This includes the domain, servers and application deployments.
• Download the Application Management Pack for Oracle Utilities through Oracle Software Delivery Cloud or Oracle Enterprise Manager Self Update.
• Deploy the Application Management Pack for Oracle Utilities to the Oracle Management Server to enable the server content.
Note: This may require a short outage on the Oracle Management Server.
• Deploy the Application Management Pack for Oracle Utilities to the Oracle Management Agents on the product hosts to enable agent content.
• Discover the Oracle Utilities Environment target using the Discovery process as documented in the Oracle Enterprise Manager documentation. All related targets will be automatically discovered.
Note: At discovery time, target names are autogenerated. They can only be renamed with more meaningful names at discovery time.
After discovery of the Oracle Utilities Environment target the following Oracle Utilities targets are discovered, registered and associated with the Oracle Utilities Environment target:
• Oracle Utilities Web Application target - One or more web application server targets (SPLWeb) associated with the Oracle Utilities Environment target. This target is associated with the Fusion Middleware Web Application Server base target.
• Oracle Utilities Web Services target - One or more business application server targets (SPLService) associated with the Oracle Utilities Environment target. This target is associated with the Fusion Middleware Web Application Server base target.
• Oracle Utilities Home target - One or more software installations associated with the product associated with the Oracle Utilities Environment target.
• Oracle Utilities Batch Server target - One or more Coherence hosts associated with the Oracle Utilities Environment target.
