Starting and Stopping Using Consoles
In the native mode installation, there are a number of ways to start and stop Oracle Utilities Work and Asset Management:
• Log in to the Oracle WebLogic Administration console for the domain and navigate to the server section where the product is installed. Using the Control function, start or stop the servers as necessary.
Note: This facility also allows enabling or disabling Administration Mode for a server. This allows administration tasks on that server while disabling end user access.
• For customers using Oracle Enterprise Manager, log into the Oracle Enterprise Manager console the product can be started and stopped using the following target types:
• WebLogic Domain
• WebLogic Server for product servers
• Domain Application Deployment
Note: Refer to Oracle WebLogic Console Operations for starting and stopping information.
• For customers using the Oracle Application Management Pack for Oracle Utilities the product can be started and stopped using the following target types:
• Oracle Utilities Environment - Starts and Stops all child targets in a single operation.
• Oracle Utilities Web Application
• Oracle Utilities Web Services
• Oracle Utilities Batch Server
Note: Refer to Operations from Oracle Enterprise Manager for information on operations from OEM.
