Defining Currency Codes
The currency page allows you to define display options related to currency codes that are used by your system. Use > > to define the currency codes in which financial information is denominated.
Description of Page
Enter a unique Currency and Description for the currency.
Use Currency Symbol to define the character that prefixes currency amounts in the system (e.g., $ for U.S. dollars).
Enter the number of Decimals that will appear in the notation for the currency.
Please contact your specific product to verify whether it supports a currency with more than 2 decimals.
The Currency Position indicates whether the currency symbol should be displayed as a Prefix or a Suffix to the currency amount.
Parent topic
