Installation Options - Installed Products
Select > > and the Installed Products tab to view a read only summary of the products that are installed in the application version that you are logged into.
Description of Page
The Product Name indicates the name of the "products" that are installed. The collection should include Framework, an entry for your specific product and an entry for Customer Release.
Release ID shows the current release of the application that is installed. This field is used by the system to ensure that the software that executes on your application server is consistent with the release level of the database.
The Release ID Suffix, Build Number and Patch Number further describe the details of your specific product release.
If you have developed implementation-specific transactions, you can populate the release ID, release ID suffix, build number and patch number for the Customer Release entry to define the latest version of implementation-specific logic that has been applied to this environment. The framework provides a script (F1CustRelM) to allow these fields to be updated manually. In addition, the F1-InstallationOptions inbound web service provides operations to view and update those fields via a REST call. Alternatively, your implementation team may populate these fields as part of their upgrade scripts.
The Product Status is used to indicate if a product installed by default in the version you are logged into is Active or Inactive.
The Display column indicates the product whose name and release information should be displayed in the title bar. Only one product sets this value to Yes.
Owner indicates if this entry is owned by the base package or by your implementation (Customer Modification).
Product Type indicates if the product is a Parallel Application. A parallel application is one that is independent of, and does not conflict with, other parallel applications. Multiple parallel applications can be installed in the same database and application server.
Note:About Information. The information on this tab is used to populate the information displayed in the About window for your product.
Parent topic
