Defining Menu Options
The contents of this section describe how you can add and change menus.
CAUTION:
Updating menus requires technical knowledge of the system. This is an implementation and delivery issue and should not be attempted if you do not have previous experience with menus.
Note:Security and menus. Refer to
Application Security for a discussion of how application security can prevent menu items (or an entire menu) from appearing.
Use the “Menu Links” dashboard zone to navigate to the “Menu Application Security” portal where you can review and maintain application security information for the current menu.
Note:Module configuration and menus. Your
module configuration can prevent menu items (or an entire menu) from appearing.
Parent topic
