Checking Out an Object
You must check out a revision controlled object in order to change it.
An object must have revision control turned on before you can check it out.
When you first create or update an object a dialog box informs you that the object is under revision control. You can select OK to check out the object and save your changes, or Cancel to stop the update.
1. Go to the object that you want to work on.
2. Select Check Out in the Revision Control dashboard zone.
