Forcing a Check In or Restore
You can force a check in if an object is checked out by another user and that person is not available to check it in.
You must have proper access rights to force a check in or restore.
To force a check in or restore:
1. Go to the object that is checked out by another user.
2. Select Force Check In or Force Restore in the Revision Control zone.
The Force Check In option is the same as a regular check in. The Force Restore option checks in the object and restores it to the previously checked in version.
Parent topic
