Terminate Steps
Terminate steps cause a server-based script to end processing successfully or issue an error.
The following additional fields are required for Terminate steps:
Error indicates whether an error should be thrown or not. If error,
Error Data Text must be specified, indicating the error message and any message substitution parameters.
Refer to Edit Data Syntax the actual syntax of initiating an error message. Note:
The ability to terminate a step in error is only supported for server-based scripts.
Parent topic
