Using the To Do Type Detail Panel
The To Do type detail panel displays further information about the selected To Do type.
In the To Do type detail panel, you can navigate using the following options:
• If the To Do type references a creation process or a routing process, click on the batch process to view its detail in the batch control viewer.
• Click on the table listed in the drill key section to view its detail in the data dictionary.
• Click on the field(s) listed in the drill key section to view its detail in the data dictionary.
Parent topic
