Configuring Your System for Statistics
If your product provides statistics use cases that you are planning to implement, all that you need to do is configure the appropriate statistics control record and define the appropriate configuration for your business requirements. Refer to
Defining and Monitoring Statistics for more information.
If your implementation has identified an additional use case where you would like to capture statistics, the following points highlight the steps needed to configure the system to support the use case.
• Determine whether an additional Statistics Category value is needed. This is captured on the statistics category record. Navigate to the
Lookup page. Search for and select the
STAT_CATEGORY_FLG field. Review the values and determine if additional values are needed.
• Define a new statistics snapshot BO. This should be a child BO of the base delivered BO (F1-SnapshotRoot). Its schema should define elements for the specific information that is captured by the statistics calculations. The schema should be designed in conjunction with an appropriate Enter Status algorithm for the Complete that calculates the statistics as appropriate for the business requirement.
• Once the snapshot business object is designed and implemented, configure the appropriate statistics control record.
Parent topic
