The Settings Area
The Settings Area contains a number of sections whose inputs control various aspects of the current cube view.
Selection Criteria
Open the Selection Criteria section to enter filter values for the user parameters defined on this cube type. User parameters that have been configured as ‘Save with Cube View’ on the cube type will be saved when the cube view is saved.
Compare
Open the Compare section to enter one or more sets of criteria that are used to retrieve data sets for comparison to the data retrieved by the main Selection Criteria. Use the Add and Delete buttons to add or remove a set of criteria. The comparison values will be displayed side by side with the main cube values in the data views. Note that the pseudo dimension Dataset must be included as a dimension column in order to display comparison views.
View Options
Open the
View Options section to access buttons that toggle on and off the display of the supported data view types. The buttons can be used to change the order in which the views are displayed, using drag and drop. Any changes made to the default button settings will be saved when the cube view is saved. Refer to the
Views Area topic for more information on the available data views.
![Data views Data views](../WAM_24000/images/92Reports009.jpg)
Dimensions
Open the Dimensions section to view the list of dimensions defined on this cube type, as well as the pseudo dimension Dataset and the date/time filter, if applicable. Use drag and drop to move a dimension into the list of Columns or Rows displayed in the data views. Moving a dimension into the Unassigned list will remove it from the data views.
Format
Click the Edit button on the
Format section to open a dialog box in which conditional formatting, such as background or text color, can be defined for the values in the data grid. Refer to
Defining Conditional Formatting for more information about the formatting controls.
Changes made to the settings will only be reflected in the views when the Apply button is pressed, with the exception of the View Options, where changes are reflected immediately upon toggling or rearranging the buttons.
Parent topic
