Save Button
Clicking the Save button saves any changes you have made in the data on the current object.
The Save link
Keyboard Shortcut
Alternate Shortcut
Alt+S
Alt+Shift+S
Refer to Shortcut Key Summary for information about the alternate shortcut.
The button does not appear unless:
• You enter a page in add mode and default values are loaded.
• You make changes to an object after it is displayed (note that you must tab or click out of the field before the Save button appears).
